Picked this up for a fiver at the Nework show. I wasn't going to blog it but this corner of the forum doesn't see much action so I'll put together what I have.
Bit of an old kit, dating back to the 80's, so I was expecting some work, but it hasn't been bad at all so far. It's light on detail but I can't complain at the price.
Unsurprisingly assembly started with the cockpit. A bit barren but the decals behaved themselves and the fit was great. I chipped it up a bit and tried a brown wash but didn't like the look of it so cleaned it off later.
Next off was the missiles and rack. Both were called out in olive drab but I lightened it for the Hellfires to add a bit of variety. Molotow chrome pen emulated the glass. Later research showed many had a yellow band or two around them so might add that.
Got some colour on the rotors. Starting with the yellow tips to make life easier as the rest is black or OD. Mr Color was used so it covered easily over the white primer.
Then onto the thingummybobs at the front with lenses and sights (notice proper use of technical military terms :smiling5: )
They got primed in grey, painted silver, then the lens/sight whatsits were coloured in clear blue and gold, to be as similar to pictures as I could manage.
Then brushed with Vallejo OD.
Fuselage and engine took a bit of persuasion to come together but left only minor seams once dry. I had a go at scribing the panel lines back in after filling and sanding with varying success.
That's it for now. I don't have enough Mr Color OD left to do the whole thing so it'll probably get primed & pre shaded then shelved for a few days.
