Hi all I've just painted the black undersides and sides on my lanc, how do I do panel lines and weather black, when my panel line paint is black. (sorry not a plane man, in fact I know nothing about planes).
Best idea I think Ken. With it toned down you will also see more detail. When you look at black it is just a dark mass with detail killed. Think I would try practice on inkjet very smooth paper to the size of the fuselage cut it out roughly and offer it up to the model. Gives an idea of the contrast of the u/s to the top side.\ said:Perhaps I should remask and spray dk grey, it's actually 1/48.
It did contain a blue pigment amongst others. If 100 people looked at a chip,99 would probably say it was black. Once applied on an aeroplane it clearly weathered to give a less than uniform black appearance.\ said:Night was a mix the actually contained a lot of blue so that to was not black either....
Ian m
I agree. It might be a more sensible way of doing it. Use different shades of grey, the idea is to avoid an even black overall colour.\ said:you could use the black as a sort of pre shade,spraying light coats of dark grey around panel lines and allowing for shade,multiple coats in the centres of panels, rather than respraying the whole thing dark grey and then highlighting panel lines and such like
