Bigfoot57
- Joined
- Jun 24, 2015
- Messages
- 1,230
- Location
- Weston Super Mare
- First Name
- Colin
- Location
- Originally a small village outside of Reading Berkshire called Burghfield Common
HMS Hood 1/200 Hachette /Amati Wooden kit Build Parts 20 and a review so far
So as I stated previously this is part or stage 20 depending on how you word it
This was fitting out the rear decking and then I took some overall views of the model so far as the 1st layer of decking has been applied
This also bought my first real problem to solve namely with part 20 should have been 2 deck pieces check and 2 spacers ok where are the spacers do you see them no neither did I so I made some from the left over spru from those deck pieces just a little challenge whether they forgot to add them to the spru or mine didn’t get done correctly who knows if it’s their mistake they might include them in a later issue but it doesn’t matter as making replacements was easy anyway here are the pictures
View attachment 439793View attachment 439794View attachment 439795
View attachment 439776View attachment 439777View attachment 439778View attachment 439779View attachment 439780View attachment 439781View attachment 439782View attachment 439783View attachment 439784View attachment 439785View attachment 439786View attachment 439787View attachment 439788View attachment 439789View attachment 439790View attachment 439791View attachment 439792
That’s it you’re up to date with where I’m at till I do some more probably tonight depending on how much each issue contains
This is turning into an impressive size wise and construction quality wise model so long as it keeps like this it will be an enjoyable build
Regards
Colin
Regards
Colin
