- Joined
- Mar 4, 2004
- Messages
- 4,822
It is, if your just going to spray acrylics and enamels then the Neo is fine, if in the future then the CR would be a better choice as it has a teflon coated needle, also between the 2 the CR is much easier to take apart and clean\ said:I thought the Neo was the cheapest brush?
Depends on you, mine retails at £215 (HI-Line HP-BH) doesn't mean it's any better than the Neo or CR, I think a lot of it is down to the user, I've seen some brilliant results with cheap £10 airbrushes.\ said:I was going to spend over £100 on a brush, is that too much?
