I cant paint very good
  • Thread starter Thread starter Deleted member 4638
D
Deleted member 4638
So what cost of having someone paint for me cost to repaint loco and the figures.......you can my attempts:sick: the figures that look good i didnt do lol
Helo, Painting is something you just have to dive into and practice.
Depending on what type of models you build can determine what technique works best for you.
I myself build mostly armor so painting does not have to be a pristine affair as it would be in autos or aircraft.
You also might want to look into using cheap water based acrylics such as craft paints instead of expensive
"modeling paints" that's all I use and I feel the end results are good.
Painting figures especially can be very frustrating even with my 40 odd years of modeling my figures
generally suck, that's why I avoid them like the plague.
Don't get discouraged, after all modeling should be an enjoyable hobby and a distraction from the tedium
of everyday life. Keeping your mind sharp and giving you a challenge to learn and achieve something new
can work wonders on one's psyche.
You will improve with time and soon you will begin to be satisfied with your results.
I myself am a brush painter and never used an airbrush but many swear by them and achieve excellent results.
You may want to try them out and they are not prohibitively priced.
Good luck to you in your future endeavors and don't hesitate to ask for help or advice as all on this site
are very kind and always willing to help.
Jim.
As above, I only brush paint and am not very good with figures, but I'll have a go.
Did a couple of 1:12 figures, first one was a bit ropy, the second one was ok.
Done quite a few 1:35 figures now and although my shaky, sausage fingered, hands can't do really fine detail, they turn out ok (ish).
Have even done a few tiny 1:72 figures and again, I can't do the very fine detail, but they are passable, if you squint!
Plus there are lots of online videos showing techniques for figure painting.
Just practice a bit and see what happens, good luck with it....cheers.
I’ve posted a couple of figures painting SBSs on here in the past based around 1/56 (28mm) and 1/76 (20mm) scale figures. Probably still worth a look if you can cope with the small pictures resulting from the recent software changes.
