WELL Dell i dont know about Peter but in my opinion its just havin the patienceSorry Peter, I don't have the history behind your Moth issue? What is the attachment problem with the wing?
on both the matchbox and the icm versions the struts are individually attached and are a pig to line up the icm is even worse as the struts are very thin and move around so until i have the patience and the mojo they will stay in their boxesWhat is the attachment problem with the wing?
AHH I see, I had this issue with a Red Baron Fokker, I stuck with it but it put me off multi wing aircraft!!!on both the matchbox and the icm versions the struts are individually attached and are a pig to line up the icm is even worse as the struts are very thin and move around so until i have the patience and the mojo they will stay in their boxes
