Updates are looking good Jim
Most impressed with that jig, perhaps you should market both Jim. aka Jig man Jim :thumb2:Thanks once again for your continued support, it means a lot :thumb2:
All the main body parts were cleaned up, built up and given a quick blast of Stynylrez primer and then grey (Tamiya XF-22)
To fit the body I wanted the wheels on to create a stable chassis to work on. However I didn't want to fit the wheels at this stage so I used scraps of wood to make a sort of cradle/jig to hold everything secure with the wheels just dry fitted.
Then a fair bit of fettling and a dry fit - seemed to be pretty good. I had to remove the steering wheel and the gear levers. The pale blobs on the seat area and the floor are where the parts were Blu-taced to coffee stirrers and I sprayed the wrong side :rolling:
Rear bed and front mud guards glued in place.
Next up the awkward bits :thinking:
Onwards and upwards.
Made a fair bit of progress although there doesn't seem to be a lot to show for the time at the bench.
PE chequerplate for the side steps. The PE just didn't fit well and so it needed a fair bit of adjustment. Looks OK now I hope. I also put some scrapes in the mudguards to help with the weathering later.
A few bits added to the cab including the gear levers which I had to remove to get the floor fitted. Also the sides fitted.
Scuttle (I think that is what it's called) across the top of the dash. Needed a little filler at each end. Also started adding bonnet fasteners etc to the front.
Exhaust is provided as two pieces. No way would it fit like that so I cut the rear section into two and added a joining bit. Most will not be seen but a bit will.
This is where lack of forward planning shows up :rolling: To fit the exhaust I need the vehicle upside down but I'd already fitted some fragile bits so I had to spend time building a jig to hold it securely and without damage so that I can fit the rather fiddly exhaust.
I have built the side and rear panels with their PE mesh and also cleaned up and primed the tools.
This kit is a real mixed bag. I can go from praising it to swearing at it from one minute to another!
I’m not sure about that. For my Dragon Sd.Kfz. 7, I built the full exhaust and then cut it like Trumpeter provides the parts in the first place, after which I could manoeuvre it into and out of the model with little difficulty. (I did this because I wanted to paint it separately, and that worked well enough.)Exhaust is provided as two pieces. No way would it fit like that
:thumb2: thanksJim, before you lay some paint down the inertia starter cover (photo-etch part) sits on the outside of the small tubular bulge in the fender
