Well i'm a little humbled there's so many people watching this....no pressure then eh
thanks for the comments so far
@ Tony ... the asteroid is mentioned in a couple of episodes and a lot more detail in the first book (infinity welcomes careful drivers)
@ Laurie ... no toothbrushes here but a few other make-shift items being used ..
@ Ole ... You can't have too much of the Dwarf mate ... don't be such a gimboid
So then .. started laying down the detail again, using kiddies foam sheets as theyre thin and flexible, easy to cut and cost a tenth of balsa of the same thickness, for thinner panneling i'll be using plain old card.
Got the bottom done, thats all im doing to it as it'll not be seen in full, there's limited (if any) pictures on the web showing this in any detail so i'll leave it a this.
View attachment 66831View attachment 66834
Got the rear thruster rings sorted, its an old wooden embroidery hoop that ive disassembled then drilled and threaded wire for strength, i fitted plastic pipe over the wire for the look i want.
View attachment 66833View attachment 66835View attachment 66836
couple of picture to show the progress of the panelling
View attachment 66832View attachment 66837
Then a quick spray over to make sure i haven't gone over the top and it all looks right
View attachment 66838View attachment 66839View attachment 66840View attachment 66841
A few very small detailing bits to add to this panel then i'll start working on the recesses between the two side panels, there's a lot of detail to go in them.
