It looks a bit rough in the photos but that’s because it’s much larger than IRL — the decals are maybe 5 mm long, so it’s hard to see on the actual decals that it’s not been done all that neatly.I would never have thought of painting decals but it's worked fine.
I suspect not well enough that it would really have been worth the trouble. Two of the main reasons for using a hull-mounted gun are because it’s cheaper and it makes the vehicle lower. That last thing was achieved here, but I’m not sure this would have been much cheaper than a Leopard 2. Two guns would rather up the cost compared to having only one, and autoloaders also aren’t overly cheap, I think — certainly not in the added maintenance and spares compared to not having one. But it would be able to put rounds on target at more than twice the rate of any MBT … at least until the autoloaders are emptyI'm wondering how it would have behaved if it ever saw combat.....
Going back to Shermans i managed to track down a Resicast m4a4 DV hull from Ultracast in Canada.A mere snip with VAT etc to U.K for nearly 64 pounds.Glad i got one but ouch it stings at that price!!!.Did manage to get some Tasca m3 bogies cheap off e.bay tho.If i had ordered from Asuka it was 30 pounds more than what i paid.It is a strange beast, but then, in the real world it was never intended as an actual combat vehicle prototype. All it ever was, was a test bed for the idea of using two guns to achieve a higher hit probability. In real life, it turned out that the advances in fire control systems made for the Leopard 2 removed the need for this kind of salvo firing.
Yes i think i can piece the markings together from various sheets.I know Star decals do.79th Armoured stuff.The turret numbers are plain white i hope.The 40 on the glacis i shall try and track down.The only problem might be the side numbers.I did ask Johan at Star if he would consider doing a set as an add on to his 79th set.He seemed quite keen and i supplied some references.Peddinghaus has the well known Sherman V " Spiteful".Sadly only available in 1.16th scale.Nice one, that should be doable from those photos, I’d say. Looking forward to seeing you build it :smiling3:
I get bored fairly easily, especially when there’s things to do on a model that I don’t enjoy — such as messing about with epoxy putty or having to redo stupid paints that lift off a model when you put masking tape over them. Plus, this one keeps getting in the way (literally) for working on the AVRE, so there’s more need for it to be finishedIt seems you have a lot of things going on at the bench and I'm so confused.
It does look like that a bit, now you mention it. Next up for building, its little cousin, the M113 FSCV:This is looking really great and your work is excellent as always. The more I look at this vehicle, the more it looks like an M113 on steroids with the 2 guns. They just had to move the driver's compartment and the motor to fit the 120's.....
You are not alone !I have much the same problem, and when I get a new idea in my head, I end up not working as much on the things I’m currently building, even though I also don’t start on the new thing yet because I feel I shouldn’t start another model before the others are finished.
Definitely not!You are not alone !
