Just a random question ?
Dustbin
Is it possible to use "Sharpies" for fine lines over acrylic paints, or would that be classed as a dumb question :thinking:
Don’t see why not. I occasionally use technical pens for fine lines, and that is a fairly similar idea.
Like all things if it works use it. Warning, from past experimentation test it first.
I tried sharpies but I found that they were not very effective. Much better are Posca paint pens. Get the ones with a fine tip. I use them all the time now mostly for knobs and switches.
I use 0.05mm fine permament markers on occasion over acrylics with no problems.
But check they are permanent, to my knowledge they are less likely to fade over time.
For me I use a speck of paint on a fine brush. More accurate.
Advantage go all little astray water on a cotton bud to the rescue.
Permanent markers are permanent as soon as you hit the plastic.
Also hate when I have used pressing on the nib to produce ink. Nothing happens & then the whole thing floods.
Tut having one of my bad grumbly days. Never mind Tuesday is an even number day.
Thanks Guys, I will try an experimental job first,with a top coat of varnish if it works. If no joy then I will seek out the paint markers.
Paul
Unless you count Sunday as the first day of the week Laurie ;)
That depends Steve entirely on what month I am in & the position of the moon in relation to the sun.
Despite all that scientific knowledge it can be come arbitrary.
Are you American or something? :tongue-out:
Jakko I prefer something please.
Look as though Tuesday, so far, is a no day.
... when glimpsed through the sarsens at Stonehenge too I assume!
Not likely Steve through one of these.
German relic of the occupation of Jersey by the Nazis.
Peacetime the top is a marine station outlook occupied night & day for those who may become distressed at sea.
The blob right is Jersey's own moon :smiling6:
