Hi people! With all the posts about the GB, I thought a blow needed to be struck for the tankies amongst us! So here's my diorama using the King Tiger that I posted some time ago. It's the 'Ardennes Front' version that came with the motorcycle rider.
A few extra bits have been added with some Eduard PE, a tow cable made from picture-hanging wire, some extra figures and the bucket that no diorama should be without!
It's meant to show a tank crew having just re-fuelled & now receiving new orders from the despatch rider. I couldn't decide which pictures to show so I put them all on here!
View attachment 14133 View attachment 14134 View attachment 14148
View attachment 14150 View attachment 14144 View attachment 14151
View attachment 14161 View attachment 14162 View attachment 14163
When I look at stuff like this, I always like to see a brief description of how it was done, so that's what I'm gonna do here (in the hope that someone is interested!)
The base is a standard picture frame from the £shop. Sealed with some white glue, normal wall filler was added, using a few bits of polystyrene to add some height.
View attachment 14139 View attachment 14157
Grass was added using both a commercially available 'rough grass' product & higher tufts from the bristles of a brush also bought at the £shop. Stuck down white PVA glue, this was then painted using both Tamiya acrylics & Humbrol enamels. The groundwork was finished in the same way, using sand & soil to give it body & texture. As this sounds like a advert for a hair product, you won't be surprised to find that I used hairspray as a cheap 'fixing-agent' once the glue was dry!
View attachment 14147 View attachment 14158
The signpost has been put up by some cynical soul, showing the limited choices available to German soldiers at this time but also showing what they were fighting for-not political ideals now but just to protect their homes & families.
View attachment 14144 View attachment 14146 View attachment 14149
One thing I also notice is that many tanks or AFV's seem to 'sit' on the ground. As this is a 70-odd tonne tank on a muddy road, it seemed correct to show it slightly sunken into the surface.
View attachment 14153 View attachment 14143
I also wanted to show a wet scene both on the ground & the upper surfaces of the KT by adding a little Klear to give a slight sheen of moisture. Hopefully this has worked!
View attachment 14152 View attachment 14137 View attachment 14145
View attachment 14155 View attachment 14159 View attachment 14142
My figure painting is always a bug-bear for me. I'm getting better I think (just look at the commander on my 1st try in the Tiger I that I did!) but I'm still a long way from where I'd like to be. Just can't get the faces right!
As always, all comments both positive & negative are welcome. I'm a big boy, I can take it!
Patrick
Patrick
