Latest Acquisitions (2020)
Forgot, instructions in Japanese!! Thank god Andy sent me a mr color chart, in English:thumb2:
The LHS had a stock check and sale and I was lucky to be in touch so I reserved these... and just picked them up.
...for 27 Pound Sterling
...and 18 Pound Sterling
Also picked up a template for my tanks and wall grafitti... I had this before but lost it somehow.
Hi Richard,
not seen that Pz III with rail car before - do you get the rail track as well? Not mentioned on the box
The Stug B is another boxing of the one that a few of us are doing for Bobs Stug GB - will you be entering this one?
Good prices
Mr postie delivered two that I have been waiting for.
One that I think you should all know and the other is the two domes for my Titanic build.
Peter - hope you plan to post the Dalek build
Two more from John
ICM re-box. They have literally just taken the ICM kit as moulded and packed by ICM and put it in a new box with a new set of nice Revell instructions. Looks like a nice kit
cheap and cheerful old Zvezda kit that needs quite a bit of work
More from John too
The AK will be a solid base for 2 lots of modulation, when I eventually get back into the garage!
Its 0 C here and frost on the cars, so not today.
The blades were reduced and discounted and points down to 72 p for a pack of 5!!!
After an 11p blade, its the one I use the most.
Timely delivered too
Thanks John
Regards
Steve H
Dragon, even. I’ve got one that I built when it was new. Wasn’t a bad kit, but it suffered from “working” hinges and very thin grab rails etc. that deformed in the mould a little, and of course break easily.
Not had the Dragon incarnation but have had a previous Zvezda version. This one has new decals but everything else looks the same. Still has the rubbish hard vinyl tyres - I will hopefully be replacing them with castings of a scratched replacement I made. Have a brass RB barrel on the way for it
Picked this up today as I found the regulator on my AS186 a little clunky, this precision regulator gives me much finer adjustment.
and here it is fitted, I have left the reg and filter on the compressor and set to 30 PSI and no longer have to reach down to adjust on the fly.
Quality of life upgrade for that reason alone :nerd:
Warren
More from John too
Thanks John
Regards
Steve H
Same here Steve, ref the horrible garage, no snow but freezing. I have about 6 kits waiting for paint etc
Postie brought these today 15 pins D sub conector sent for 2 of each 2 males an 2 female's an they sent 4 of each so im very happy
boatman said:
AN I also bought a grinder like andy did as it will make life easyier instead of filein an it looks a nifty little job
Great for trimming your nails:tongue-out3:
I just checked mine, and its tyres are still good after about 25 years on a shelf, as are those of the BTR-80 standing next to it. OTOH, all four tyres on the BRDM-2 model (similar vintage) next to it have split, but on the BRDM-2 next to that, they’re fine … I’d say you might be making the right decision to replace them, just in case.
I also sent for this grinder an it looks a nifty little job one like andy boughtIMG_4996.JPG
AN a nice helpin hands with built in lights IMG_5007.JPG like dave ward bought an its great
Is that for left-handed solderers Chris?
Still stuff from C/B sale here is all different block an tackle for model shipsIMG_4998.JPG
