Leopard 1A1.......Revell 1/35
PaulTRose
Tattoine
Paul
Tattooine
Next on the bench....... After that tiddly little Ford Tc i need something bigger lol........ So how about a current-ish MBT
Kit was new tool in 2015......lots of parts in the box!...... 8 sprues plus tracks and some other bits n bobs...... Box says 233 parts so should keep me quiet for a while lol
Theres 3 schemes..... 2 german 1 norwegian...... Dont know which i will do yet
Will follow along matey, my my you are knocking them out at a rate of knots at the mo!!!! (y):D
The little Scorpion has given me a taste for something bigger.... :cool:
Lol..... Ive also just 10 mins ago finished the Celica but cant take pics til tomorrow......
Im hoping something with a large parts count might slow things down a bit
Made a start.... This is going to be bigger than i first thought
I like to add some weight to a tanks hull to make it 'sit' on the vinyl tracks........ Usually a couple of big nuts or similar is enough but the hull is so big ive had to come up with another solution...... I had some little plastic pots that was right size to fit inside..... Cut them down to right height....... Filled with little stones (fish tank medium..... Left over from when i did that dry stone wall in the infantry gb)..... Used a hot glue gun to fix in a lid.... Then glued into the hull....... Simples! 😆
Usual paint pot for scale
Lol, thats a good idea re weight. I do air rifle target shooting and fishing, so have plenty of lead laying around... ;)
I buy cheap fishing ledgers usually
Word of warning.... Dont use ca to glue in lead..... Allegedly it causes a reaction where it 'grows' a sort of crystalline fungus which over time can cause seams to crack open
I dont know how true it is, i read about it years ago on a forum, but ive not took the risk since theres so many ways of glueing in without ca
Count me in Paul.Im a massive Leopard 1 fanatic for my sins.Seat pulled up.
Rich
I thought it was PVA glue that could cause that?
I always use CA, although most of the weights I use are probably "lead substitute"
Quick Google search says that they BOTH (CA and PVA) react to Lead in a similar way.
PVA apparently has acetic acid which causes lead acetate, white powdery substance and expansion.
CA apparently has sulfuric acid which then reacts and caused lead Sulfate, white powdery substance and expansion.
Did a dark wash, not sure how well its worked..... Matt coat on top...... Tracks and a few greeblies added
Next step is do something to the tracks...... They should be black rubber with metal/rusty links joining them...might try some lighter dry brushing on edges to add highlights..... .... Then some mud/dust but just a light coat cos from what ive seen german tanks were kept in good clean nick..... And got a variety of gubbins to go in the stowage rack
