This review is of course 'only' my opinion!
In my quest to weather a wooden deck, I found this
You get 6 pots
Fouling Green
Surface shadower
Wooden deck darkener
Wooden deck shadower
Dried salt
Remover
The instructions are very poor, so nothing like just going for it. So using a cheap wooden deck ( £7.00) I started by just applying the two deck pots on there then started to mix them in different amounts. On its own the deck shadower is to brown and the deck darkener too bluey, but when mixed there's a good change. Hopefully you can see the different tones?
So below is 1st proper bash, so a thin layer of shadower, then picked out individual planks with darkener, dried and used the remover to remove excess. Tad blotchy
Next bash, I think it's a lot better than the one above but one plank needs more remover. Not ideal bit getting there.
Of course more practice needed and it will be time consuming on a battleship with multiple wooden decks. However in my opinion its a very useful product which with practice will produce good and effective results. The size of the pots will do many decks! It's also at about £18.00 good value at £3.00 a pot.
You get 6 pots
Fouling Green
Surface shadower
Dried salt
Remover
