Been tinkering with this for a couple of years and finally decided to get it out and finish the job.
First job was to get the suspension out of the way. During the build i decided to add the tension springs on the rear set of suspension..
Next longest job was the tracks. These came from the ModelKasten set originally for the Bren Carrier, but were liberated for this one. Still got a set left over for the Carrier.
And the finished items...
Obviously not been sitting around waiting for things to dry - so set to with the interior...
And the inst panel scratch built..
As you can see I have used the Eduard set and incorporated quite a bit of the brass on the build, plus I scrath built a new exhaust as the kit version is a bit clumsy...
And that is as far as the build has progressed to date. Still more fun to be had..
Cheers, MikeC.
Cheers, MikeC.
