Thanks for the support guys,
Got the main structures in place and a fair bit of the ground work basics laid out, there's a few doors still needed and the outside wooden supports and ties for the tents. The trees are twigs with added twisted wire and foliage to represent Ginkgo trees, the bushes are two strands of wire with short lengths of seperated garden twine twisted into them. (i.e. double a length of wire, attach the folded end to a nail/hook on bench, lay one wire end out on bench, glue it with epoxy, add lengths of twine across it in clumps, place other wire over top, attach both loose end to drill/dremel and slowly twist, the clumps get caught in the twists and create bushes.)
View attachment 50321View attachment 50322View attachment 50323View attachment 50328View attachment 50324View attachment 50329
The showers are finished, mainly balsa. The taps are the cross over section from mesh, the shower heads are small road wheels from a 1/72 kit, the pipes are soldering wire, the door handles are just a knotted length of thick thread. i've left the shower roof removable, the latrine is too hard to see into so i've closed it all up.
View attachment 50325View attachment 50326View attachment 50327
The tent tops are still removable so the inside detail can be seen (when it's all in there)
