You only find out how much handier it is to build Shermans that way when you need to set the suspension to a certain attitude, like to represent much weight on the front but not the rear, for which you pretty much have to glue the bogies to the hull before painting.
Oh, one thing I forgot this morning: the M10 has an inward-sloping bit to the bottom of the upper hull sides, at the level of the top run of the tracks. On the real vehicle, this is a hinged piece, but Academy has moulded it to the upper hull. You almost certainly won’t be able to fit the drive sprockets if you glue the hull halves together first, so make sure those are on before you do that. If you want to use the tracks from the kit, you will also need to add those before installing the upper hull. However, if you use workable tracks, like your preferred Friuls, you should be able to put the track in after glueing the hull halves together — just as long as you haven’t joined the ends of the track first, of course
