Me again, brush painting PE
BattleshipBob
Bob
Cardiff
As many of you will know it l have used a lot of PE on Tirpitz, inc large deck sections. So after using VMS cleaner and etch primer, i primed with mr surfacer, perfect
Next i started brush painting a acrylic wood deck colour, pleased until the bl**dy hairs turned up! So tried using a glass fibre pencil to lightly scrub the hairs off ( you probably know what's coming ) it worked BUT of course its exposed the bare and very shiny pe! Have tried 2 more coats of thinned paint but seems the same, a thicker coat would probably cover but fill in the 'planks'.
Has anybody got a idea how to proceed or is it best to leave and not do again.
Have you tried a dedicated metal primer. I like VMS Metal Prep. It is a thin, clear liquid which you just brush onto the PE.
Hi Jim, I did use that in prep and was wondering after John's replie that I could just paint it on the patch. I'll give it a go as all the build is one big practice anyway and the ship will be thrown out
Bob's black bin for landfill has now been changed to a skip !
You should keep these early kits you've had, just to show your improvement Bob.
