MENG 1/35 Chinese ZTQ 15 light tank with cage armour
Bigfoot57
Weston Super Mare
Colin
Originally a small village outside of Reading Berkshire called Burghfield Common
Here is my next build. I’m sorry it’s a couple of months or so since I posted anything but we’ve had what we call a very warm start of the summer in the fact that it’s been in the 30s and 30+ in Britain as we were underneath the heat dome apparently this is now moved over to Europe so the temperature has gone down to more comfortable manageable figures so I’m starting my next build which as you can see is a Chinese light tank with caged armour assist to protect it from drones and things like that
So first off we would normally show you the artwork from the box but in this case there isn’t any all there is is a maroon coloured box with gold writing on it so I don’t know what happened to the artist or whether they didn’t bother with it anyway, next are some sprue shots
So points of interest on this kit are the inclusion of 3-D printed parts for the cage that goes on top of the turret along with very fine meshed photo etch and digital camouflage decals
As you can see there’s not much to this. I think the most parts are probably the tracks you got about 200 pieces to link together to make up two sets of tracks. Also the sprues are very sparce so construction wise it should be fairly easy if I’m gonna have problems. It will be with the tracks again cause I always have problems with tracks anyway until tomorrow when I will begin construction. I’ll see you then.
IMG_7273.webpIMG_7274.webpIMG_7275.webpIMG_7276.webpIMG_7277.webpIMG_7278.webpIMG_7279.webpIMG_7280.webp
Looks interesting Colin. The box translation says it is a limited edition, so the red box is probably an attempt at making the kit look fancy (similar to Eduard's Royal Class Boxings). The colours also correspond to those used by the Government of China.
Good luck with the build, I like the look of Meng kits.
An eye-catching box although strange not to see a picture. I imagine it will be fiddly. Sign of the times that a kit contains 3D printed parts.
Right then so we’re off and running at last first stage of the construction is the wheels and sprockets this is then followed by the attachment of the Torison bar suspension system to the bottom of the tank
First thing I noticed is the quality of the plastic that they’ve used it is superb and it cuts very very cleanly leaving minimal and I do mean a minimal cleanup just a light sanding to remove the sprue nibs so as you can see from the instructions, the wheels are mainly two pieces with a poly insert which should allow them to be pushed on and off of the model with ease. The sprockets were a bit more involved they were five pieces to them two outer & two inner and again another poly Insert.
After this, the suspension system was started and they’ve actually mimicked Torison bar suspension system including the little links several places so that’s where we are at the moment is now quarter to one in the morning here in Britain. I’m just finishing up.IMG_7368.webp
So many wheels 😄. Good to hear it's such a good kit. Nice plastic is a real bonus.
Delay on next instalment due to extreme heat again
Sorry too hot for any model building in my flat temp 30+ yet again will resume when it drops to more comfortable levels
Finally, the temperature has gone down and we’re back with some modelling this time. I’ve done sections 3 4 & 5
This is the lower hull assembly where the wheels will fit on? So what I’ve done tonight is added all the axles then the road wheels and two sets of towing hooks. One set at the front and one set at the back this is all now left to dry before I assemble the wheels, cause I want some nice stable axles on which to put the wheels on
The towing hooks were an assembly of one piece glued to the bottom of the tank and the other pieces of snap fit so that the hooks actually swivel and it was a perfect fit. I am very impressed with the quality of this kit, especially the plastic the detail on it is phenomenal as I’ve said previously it leads very little to be cleaned up once you cut the piece from the sprue whether this is due to this being a special edition kit and they’ve pulled all the stops out I don’t know. I don’t remember a Meng kit being as good as this before Anyway here are some pictures of what I’ve done tonight. It’s not much but it’s a start after the layoff due to excessive heat.
Small update just because the temperature has gone through the roof again making it too hot to do any modelling so I did this IMG_7504.webp last night which was added the top to the bottom of the tank and installed some sort of driving vision system and as the interior of the tank is bare, I haven’t painted it and I’m just gonna close the hatches down cause there’s nothing to see inside I used to head torch to shine through the tanks turret attachment point so you could see the blue of the drivers vision panel next on my list is to do the tracks which are always my nemesisIMG_7477.webpIMG_7478.webpIMG_7479.webpIMG_7482.webpIMG_7483.webpIMG_7489.webpIMG_7505.webp
