Meng 1/48 Me 410
Hi all,
This is the start of my build of the Meng Models Me-410 B2/U4
As you can see from the box, it's the bomber-killer with the 50mm gun :)
As is traditional , I've started with the cockpit! I painted it RLM 66 & then lightened it up with a touch of white in the mix.
First the pilots bit
The instruments are (badly!) painted in accordance with nothing other than my imagination ;)
Then the rear gunners station
A quick silver drybrush, the Eduard seatbelts & we're done. I'm not going to bother with a wash.
Thanks for looking
Patrick
great looking start Patrick ,the office looks killer! Watching this one,got 2 of the Pro-modellers in the stash eager to see this come together!
Nice start Patrick , I'll be watching this , ive often fancied doing a 410 , cheers tony
Nice start on the cockpit, will be watching this.
Scott
Thanks guys! I really like the lines of the 410, it's like the German Mosquito.
To speed things up, I'll probably cut some corners - the cannon gunbay under the pilots cockpit can't be seen, so I'll probably skip that area.
The cannon can be recycled into another project ;)
Nice start. I like the 410 too. Never heard of Meng as a brand, I'll be interested to see this one.
\ said:
Hi all,
View attachment 110933 View attachment 110934
Thanks for looking
Patrick
Nothing wrong with using ones "imagination" at times my friend! GREAT work so far! ;)
Looked at the Meng site the other day, the tanks look fantastic. Take a peek
Thanks guys, there should be more to post soon, once I get the camera out!
Ca'nt wait to see some pics Patrick and its all you're fault I just moved the 2 in my stash to the top of the next to do!
After much trials & tribulation (not to mention swearing!) I've got the fuselage together.
Meng don't believe in guide pins etc, and the ' snakehead ' shape at the forward end means using clamps in ways they weren't designed for!
Also, because so much strength is needed where the clear part of the nose joins, I had to use CA cement, so fingers crossed it hasn't fogged up.
I managed to break off the canopy bracing :(
Wings are also well on their way to being done, just a few bits needed here.
You do get 2 nicely detailed engines, but mine won't be on show, so they're just there to have something to hold the exhaust stacks & props.
Finally the 5cm BK5 cannon pod.
Thanks for looking
Patrick
Looking great Patrick! Just a fyi , use foam safe Ca it wo'nt fog clear parts. Eagerly awaiting the next update!
That office is looking very good, shall be watching this one.
