MH-53e, HC-4 Sigonella - Italeri 1/72
Wow, Francesco, you you must have macro-eyes for that level of detail in 1/72. The scratch work is awesome, the fading/salting looks spot on to me.
Just amazing.
Si:)
Let me say thank you with a small update.
The main rotor is now complete (just few scratches to be fixed and a couples of tubes to reglue).
I moved my attention to the tail rotor, especially in the pitch system which not reproduced in the kit. To represent it I used the pitch levers from Eduard PE bending them a little and shortening the links, then I scratched the shaft (missing) and protection for the levers (totally wrong).
The result you can see below together with the real one.
Francesco
Top notch. The interior looks like the real thing !!!
And to top it off, this is 1/72 scale !! Great work.
More enhancement, looking good Francesco. All this attention to detail is going to pay off for sure.
You must have very good eyes, Francesco. Really good work the level of detail is amazing.
Thank you mates.
I'm closing the fuselage today, I need to speed up as it's already three months since I started it (with the Sherman in between).
Not so good Ian, not so good.
Francesco
Happy Sunday mates.
Just to let you know I'm alive and modeling.
Current status:
• fuselage closed
• added third arm to the swash plate (missing in the kit!)
• moved handrail on the roof (straight in the kit, but with the front shifted to the right in reality)
• modified APU air intake (front too thick, back closed in the kit)
• modified air intake over turbine 3 (too rounded in the kit)
• modified support for the bottom cranes (should be attached on center line and closed when not in use)
• added some PE
• added skid training arm to the cabin roof
• shortened main rotor shaft (too tall in the kit)
Mistakes/forgotten:
• Opened the fuselage under the grilles (now you can see side to side through them)
• Not opened the fuselage under the APU grilles (at least you can't see through, see above)
• glued sponsons before closing the fuselage. to get a good fit I inadvertently deformed the bottom middle of the fuselage forcing me to use a lot of putty to properly close the fuselage (and losing rivets)
Next steps:
• cockpit and windshield assembly
• fuselage final assembly (antennas, pitots, etc.)
• final primer
Thank you for reading and hope you like it
Francesco
Looking great Francesco.
As for the vast amounts of putty. I think you might be exaggerating just a bit.
Cheers.
Nåh! ALL that. Trust me I have seen much worse. LOL
Still if its got to fit, there are often no other options.
Ciao
Your chopper's looking amazing...:eek::oops:, I mean your helo is looking brilliant! :D
:P
Lee:)
Looking great Francesco, an amazing amount of detail on so small as scale, well done. Cheers Derek
Just caught up on this one again Francesco some stirling work there mate and in 1/72 I feel so inferior keep it up
Thank you for stopping by and writing.
Cockpit completed (lower part). Unfortunately I sprayed some primer over the cockpit floor, even if not visible I will try to recover.
Landing gear complete.
Tomorrow some pictures.
Francesco
Amazing work Francesco, only a little error and easily rectified. Lucky it wasn't on clear parts. The cockpit looks great, as do the wheels with the extra bits.
