MMM 200mm Obi Wan Nairobi ( Chris Craighead )
Steve Brodie
Started on this at the weekend, funnily enough a new mini drill kit i had ordered from amazon also arrived so put it into use, it does create rather a lot of resin dust, so a mask is required when cuting and sanding bit, however it's pretty amazing at doing what it does and for such a great price and its cordless (£22.99) you can get one from here -
I have already done a review of the kit over here
Upper and lower torso joined and gap filled with some milliput. Sanded smooth. small resin gates ahve now also been removed;
Boots attached and pegged to a block of wood for painting, not sure about the position of his right foot though, may need to break it off somehow and re attach ( at the end);
Head is just dry fitted, after removing the pour stub under neath his head.
Got all the flesh areas, face and hands, blocked in with base tone. Painted in the eyes, need a bit of work on the right eye, but please overall with the outcome. next to bring life to the face.
All the main colours blocked in, redone the balaclava , was to grey and not as brown as it should be. Sometimes the web can be a curse for reference images. different cameras give off slightly different hues, colours. Matching the rifle has been a nightmare and still not totally convinced on the colour, however it may come out okay once weathered a bit and had a matt varnish on it.
View attachment 423958 View attachment 423959
View attachment 423960 View attachment 423961
View attachment 423962 View attachment 423963
Cheers chaps, arms are not glued on, just blutack.
Yep rifle totally wrong colour. So;
Balaclava repainted as more a brown colour and not grey, hair has had a dark brown wash added to tone it down a bit. Shirt has had highlights added and rifle repainted in light green with tan camouflage added, ordered a brown unipin pen to draw on the waffle pattern.
Needed to start on the Camouflage, so tried it out on the rucksack / backpack first, happy with the results, shadows added by inks and highlighted with pigments.
Camouflage painted onto the front vest and ballistic plate, side straps also painted, so will be able to glue the arms in place , once i get the pens for the waffle stripes on the rifle, oh and painted in the time on his Garmin watch. Shirt has had subtle shadows added;
View attachment 424684 View attachment 424685View attachment 424686
Front ammunition pouches done. The velcro areas just visible under the flaps was created with some Mr surfaces, stipple on with an old brush.
Havent had chance to get any painting done recently, but have now finished off his trainers, custom colours mixed to try and match the photos;
