Model Makers Marking Out and Cutting Jig For Scratch Building (10cm)
peter.collins443
To much time on my hands Lol lol. I needed some blades for my modellers knife, ouch the price for the blades I may as well buy a new set. I came across this for sale
It peaked my interest its 10cm x 10cm and a nice price tag of £4.35 or best offer plus £2.26 or a larger on at £10.24 plus pp.
Ive ordered the small one too help with cutting more pieces of balsa wood....
Link to the item
once it has arrived Ill give it a go and let you, that's when my new saw's arrive...
Peter
The jig has arrived this morning.
The size is about 8.5cm x 9cm and not 10 x10 cm as first told.
I was not initially impressed with it on first arrival. playing around with it a little more may change my mind.
I may have to slightly amended it, then might work a little better.
The most of putting thing with it is the text that runs round the base of the jig (Cut/ mark/ join and Do not heat). As it raises the balsa wood about 1mm higher and creates issues while cutting the length required. As your having to look down on the wood to try and keep the cut straight all the time.
Value wise its not bad, but I think I should have bought the larger one instead but being limited to space it looked okay.
I've ordered the bigger one, might help a newbie like me.
I was wondering that too John. The ebay link shows a couple of uses.
I think John race was trying to establish what the jig is made from.
Is it die cast metal or something else? The do not heat notice on it suggests it might be made from some sort of plastic or resin.
If plastic or resin, probably not the best of materials to use for a cutting jig ?
Agreed. It looks like a 3D print Andy !
Metal is the way to go for any cutting jigs with regard to being accurate and robust in my opinion.
Sorry not making contact and reading the posts been under the weather, to darn hot, the jig is made from a hard plastic and from memory the person said they printed it on a 3d Printer. Hope that helps
Peter Collins
