Modelling Drill
One thing I find helps when drilling holes is to mark the start position with a "dimple". I use a large pin with a round head.
I find I can position the pin point accurately and the big head lets me press to make a mark. The drill does not tend to slip then.
That's a valid point ( Not an intended pun either) Jim, this is where my drills snap as I press to hard to get started. I will use this method next time, cheers.
John.
John.
It doesn't matter what method you use if you apply too much pressure and your drill bit is not perpendicular to your work surface it is a recipe for disaster. Everything else is subjective.
Rick H.
The pin thing works great, but I also graduate the bit sizes to help things along if brittle plastic or cursed resin. Heating the pin a bit helps w/harder plastic too. I also store the eighties & seventies in a chunk of beeswax to lube them as I used to break a lot of them. PaulE
Thanks Paul
Some good tips there. Particularly like the bees wax idea.
I was talking to a Dremel rep at an exhibition today, he told me that all their drills have a minimum speed of 10 000 rpm, except the 400 series corded, which is 5 000. He couldn't offer any suggestions for achieving a lower speed. I think I'll rig up a mains socket with a series diode - that used to work with the old thyristor speed controllers, not sure what it'll do to my Dremel though.
That's way out of my comfort zone I am afraid Pete/PaulE but a terrific idea which I am sure will be picked up by the other modellers here. Thanks for the link Bob I will have a good look at that one
Thanks for all the input guys. Much appreciated
