Monogram 1/48 Mosquito mk2
Now the Airfix Mosquito is finished,I can spend more time on this one.After two rounds of filling and sanding ,the nose to fuselage join is done.As often happens when a dry run shows a good parts fit,they don't fit that well when glued together.So a bit of filler was needed.The wings needed a bit of filler around the engine cowling joins.Then I glued the wings and tailplanes to the fuselage.
Thanks for showing the flaws dave , I have the revell release of the MKIV for Christmas so it's a big help for me to know what's instore :)
Are you sure you've got the same kit Alan?.Revell also do a newer tooled mk4.This is the ancient Monogram kit.
Of that I'm not sure all I know is it's in an old box and is now wrapped under tree , wife bought it and wouldn't let me take a look at it
\ said:
That's the old Monogram kit reboxed then.The one I'm building here.Its not a totally accurate Mosquito.But if I hadn't just built the Tamiya and Airfix kits,I don't think I would have noticed!.
That's a relief dave I can use this thread to get around the problems when I build mine :)
The undercarriage doors are moulded as part of the engine nacelles.If you want the gear down,they have to be carefully cut out then cleaned up.Door hinges are supplied as separate items.Ive masked the canopy frames this evening and glued it to the model.And I've glued on the wing tip lights.These needed a bit of plastic card to make them a better fit.The kits .303 machine guns are way over scale.So I've got some 'Master' brass barrels to fit in their place.On this build I've decided to fit them after painting and finishing the model.So I've filled the inside of the nose with scrap plastic.And I've filled the oversized gun ports.I will drill holes for the guns and fix with superglue at the end of the build.View attachment 208266
Thought I would try out the spray booth I got for Christmas.Its very cold in my garage, so I used Alclad grey primer on the model.It doesn't seem to be affected by the low temperature and has dried as quick as usual and give a nice,smooth finish.View attachment 208609
Very nice dave :)
I'm building that airfix one at the moment but I'm further along and already have the base colours on which means yours will look better than mine :D
\ said:
Very nice dave :) I'm building that airfix one at the moment but I'm further along and already have the base colours on which means yours will look better than mine :D
I doubt it will look better than yours Alan.I may appear to be taking my time with this one.But the reality is I haven't had much chance to do much modelling lately.Family stuff keeps getting in the way!.
Nah dave ive rushed mine and left out some filing and I got the underside colour wrong , i cose what I thought was a mid sea grey mate but ended up with a stone grey gloss and me and gloss don't get on so the surface is full of brush marks and will be difficult to weather , top side is fine but to much rushing for the 1/24 SSIG has made me do stupid mistakes
