hey oggy,
for a first model you are doing just fine...
try to sand away this glue marks on the wing fuselage joint with hi grade sanding paper, let me say 1200 mesh.
an also engline cowl joint iun front of canopy and also filled place on the belly...
and when you sanding do it with water, put sanding paper into water and sand away with wet paper...
you will see how will be better and you will not damage plastic with hard paper or some stick...
try that for start, you will see good result
Roman
Roman
