Normandy Bocage diorama
Sorry. I just had to try and see what it looked like semi in-place.
Figures will be the icing on the cake. Gate looks great.
The figures will be the first thing to pose on the dio. Got to try and decide what armour will be next after them. I have the 251 with Pak 40 or the Tiger I to build. But i might have to stray back into my comfort zone and do a wingy thing lol
That last pic reminds me of the real area near where the 10.5 cm battery was in Band of Brothers.
The 'pins' are fixed to the post in theory ;)
This is the way i've made them so that i can actually fix them together.
So basically i have placed the female hinges (one with the hole) onto the gate but placed the male pin on top as if it's already sticking through it. This is so i can make the post hinge as a flat piece that the gate hinge can 'sit' on top of, thus making it look like a made up hinge.
Hope this helps clear it up
Got your meaning :thumb2: , now that you've explained it, can see what you're doing, thought that you were building the gate so that you can open it to various angles;)
Started to add foliage. But think i am going to run out of scatter. Using a lot more than i thought it would. will need a little bit of clean up after it's done but i don't mind that if it gives decent results
Cheers Paul. Have to say i am really enjoying making this dio. Always something to do on it and it keeps my mind active. But not much more to do now after the trees and gate before i can call it done (for now).
Hi Alan
You really are in your element here. It is looking superb. All credit to you for your willingness to learn as you go along and experiment.
I wouldn't say 'in my element' as it is totally out of my comfort zone. But as you say. It's all about learning and experimenting. I've taken plenty of hints and advice from you guys on here so much of the thanks has to be directed towards those people including yourself.
Just the top section of the tree to go. Never thought it would be such a slow process in putting the scatter (leaves) on. I suppose that now i've done one tree, i'll be quicker next time. But it's way more stressful than i thought it would be but i am trying to add the leaves in a methodical order so i'm not gluing over other sections where possible.
Just a few bits to clean up. The glue can be a little 'stringy' but at least it grips the scatter and holds it. Also had to re-attach a branch as i broke it off. rather a lot of swearing was done.
Well the first tree is done. Needs a clean up but WOW. It totally transforms the diorama imho. Even the shadows it creates is exactly what i was trying to achieve. Have to say. I am well chuffed!
Now for the last two trees and the gate.
Looking forward to seeing the end result Alan this is coming along fantasticly.
