Could be either, I suppose, but I’ve not investigated enough to tell for sure. Tim’s reply doesn’t bode well for my desire to avoid that, though :smiling3:
Anyway, I sprayed the underside yesterday and then went on to draw a camouflage pattern onto the model this afternoon:
T = tan, m = medium green, d = dark green. This is based on the pattern for the F-100 Super Sabre, because the F-107 started out as an improved version of that before being given its own designation:
source)
And then I started spraying the upper sides using the Hataka paint set I had bought previously. Well … judge for yourself:
I started with the tan, which didn’t really want to come out of my airbrush no matter what I tried. After over twenty minutes of trying to make it, including emptying the cup, spraying water through the airbrush and trying again with paint thinned with some water, I had painted
one patch of brown on the left side of the tail and chucked the airbrush into my ultrasonic cleaner for about a quarter of an hour.
Once it came out of that and I filled it again, it did spray the paint reasonably well, but it hardly covers at all :sad: Each of those brown patches has at least five coats on it just to make the pencilled letters disappear. I decided to just paint beyond the lines and then get rid of them later with the greens, because there was hardly any point in trying to do so with the tan. The fact that I couldn’t get it to spray any fine lines at all also didn’t help in neatly painting the camouflage.
So, on to the green, which I hoped would do better:
At this point, after about an hour and a half of toil (including sitting on the sofa stewing while the ultrasonic cleaner did its thing) I said, “To hell with this paint” and cleaned my airbrush. While I was busy doing that and cursing, probably the most appropriate song possible came from the radio in my hobby room:
Thank you,
KINK :smiling3:
I will not be buying any more Hataka … Hakata …Ha
whateverthehelltheorderoftheTandKis paints, I think. The ones I used on my Dewoitine 520 a while ago worked reasonably well, but in general, they all cover like … I was going to say “like crap” but that does tend to cover well, I think, so … like coloured water, I suppose. Maybe some people like this, but I know I’m not one of them — I want paint that
covers. I don’t want to build up layers to get the right transparency, have pre-shading and all that kind of modern stuff — all I ask is paint that obliterates every colour underneath when I spray it. This appears to be too much to ask from modern paint manufacturers, though :sad:
