Y thats true. I am a Airbrush guy. But is the tamiya paint the best paint for Airbrush and modells?Hei Benjamin
Sprayer du eller penselmaler du... gjør en stor forskjell for malingsvalget ditt.
Tamiya are well regarded for use in an airbrush but the best airbrush paints are, without a doubt, lacquers.Y thats true. I am a Airbrush guy. But is the tamiya paint the best paint for Airbrush and modells?
Thx, these paintssounds great, i have only been using tamiya and few times humbrol. But these sounds amasing. So i think they will come handy for camo and aircraft painting. But to cokpit i will still use tamiya like kockpit green as its so good paint for RAF planes. So on. But thx for your answear!Tamiya are well regarded for use in an airbrush but the best airbrush paints are, without a doubt, lacquers.
My preference are the MRP lacquers for a number of reasons.
1/ They have a huge colour range so no mixing at all is needed. Paints are identified by their FS, BS, RLM etc codes so matching to a scheme is easy enough. That is a clear advantage over Tamiya with their limited range of colours, not always clearly identified.
2/ They come in large 30ml bottles (10ml Tamiya)
3/ They are ‘airbrush ready’ and need no thinning with a very fine pigment so they spray like silk at a very low psi (10-15 or even lower). I have never thinned MRP (or mixed colours) over the last 5/6 years using them. Not even for mottle and fine lines.
4/ De tørker veldig raskt og er klare til å maskere over innen 30 minutter, og det er trygt. Vannbaserte akryler tar mye lengre tid og må herde før du kan maskere dem.
5/ De fester godt og er relativt robuste. Mye bedre enn vannbasert akryl med stor margin.
6/ Fordi de ikke trenger noe tynning og er konsistente mellom farger, har de en kort læringskurve. En av utfordringene er balansen mellom psi, tynningsforhold, avstand etc for airbrushing. Disse eliminerer én faktor, tynnere forhold gjør dem så mye mer brukervennlige.
Det er ulemper, og det er greit å nevne dem.
1/ De lukter. Dette betyr at du virkelig trenger en god sprøyteboks som kan trekke ut gjennom et vindu.
2/ Overskriftsprisen på litt under £5 er dyrere enn de fleste. Men husk at de holder to til tre ganger så mye maling som andre merker i flaskene. Du får tross alt det du betaler for og kvalitet koster.
3/ De er ikke bra for håndbørsting. Jeg holder et lite utvalg av Vallejo MC for å håndbørste fine detaljer over MRP, omtrent 11/12 farger er alt som trengs.
Alt i alt hvis du leter etter de beste airbrush-malingene, så er det det jeg vil anbefale.
Tx. I use online shop like poland to get resin. But my hobby shop birkemo has all the tamiya paint. I will tho search for bether paint. Have seen valjor made some paint kit for specifyed planes. But i will chek it up as some stores in norway maybe has that paint.Og for ikke å glemme at Tamiya nå også har et utvalg av lakk.
Så er det også det du kan få i din del av verden. Jeg husker at du er i Norge, men aner ikke hvor 'lett' det er å få ting dit. Er det mange faktiske butikker for hobbyen vår, eller er du også 99% online hobbybutikker?
Vallejo modell luft er ganske bra og fargene bedre navngitt så lettere å finne, ikke som modellfargespekteret deres! Også klar til bruk, men mange tynner dem enda mer.
Vallejo modellfargespekter er bra for både pensel- og airbrush-arbeid. Noen få eksperimenter om hvor mye den skal tynnes og det beste lufttrykket. Når den er herdet er den ganske robust og vanntett. (en hobbybutikk for RC-båter her bruker dem hele tiden til sine egne bygg).
Lakkmalinger er enkle å bruke, tørker raskt, men ettersom Barry berørte vanskeligere å reparere maurskade/bortkomne deler. Ikke umulig bare vanskeligere. Du må "røre" området (derav navnet, touch up?) med små, men tilstrekkelige prikker med maling.
