I am really pleased you are doing this as once and for all I can get the order of painting right ! keep it up
I can also see an approximation of what my painting SHOULD look Like at each stage
Thanks Patrick, i was thinking about Vallejo because all the reports i've heard are good.\ said:To be honest John, I'm still undecided on that front. It does go on well but still seems to leave a slightly 'gritty' finish, even with some retarder added. I'm going to try using some lacquer thinner that I've got to see if that helps because I've still got quite a lot of Tamiya paint to get through! As I run my stocks down, I may try Vallejo because using the double-action means less paint & their 'eye-dropper' system seems great for popping it directly into the cup.
I'm not sure about laquer thinner,it's very hot stuff. It will melt styrene undiluted. If you haven't got the Tamiya thinner I'd try isopropyl alcohol (90%). I don't use Tamiya but a friend does and he recommends it. His paintwork is always very good. You can get it from Maplins.\ said:To be honest John, I'm still undecided on that front. It does go on well but still seems to leave a slightly 'gritty' finish, even with some retarder added. I'm going to try using some lacquer thinner that I've got to see if that helps because I've still got quite a lot of Tamiya paint to get through! As I run my stocks down, I may try Vallejo because using the double-action means less paint & their 'eye-dropper' system seems great for popping it directly into the cup.
i've heard that lacquer can be very 'hot' Steve so I plan to test it out on some scrap first-don't want to ruin a perfectly good kit! All part of that never-ending quest for perfection!\ said:I'm not sure about laquer thinner,it's very hot stuff. It will melt styrene undiluted. If you haven't got the Tamiya thinner I'd try isopropyl alcohol (90%). I don't use Tamiya but a friend does and he recommends it. His paintwork is always very good. You can get it from Maplins.The Vallejo "eye droppers" are really good. I use a bit of their Modelair range from time to time and it works well.
