Sorry people silly Question time
Do I need to use a airbrush to do panel line? or can I use a hairy stick. if I can what is the thinning ratio as I use enamels for my painting
Thank you all
Russ
You are mixing up two thing I believe. If you mean pre-shading then you do need an airbrush but pre-shading is not about panel lines it is about modulating colour to create in miniature the way a large area of colour looks in real life, with light being reflected from different angles you do not see a solid block of colour. Colour also fades and can bleach, in some cases it actually darkens instead of getting lighter. Pre-shading and post-shading helps with this though it is true that often people use panel lines on an
aircraft as a basis for pre-shading as panels can be 'pulled in' at the edges by rivets and therefore reflects light differently. It looks best if you do not pre-shade too neatly along the panel lines though and work other areas as well that may benefit from being highlighted.
What I think you may be referring to is how you replicate dirt and shadow in panel lines. That is best done by a wash of a thinned colour. There are both enamel based and water based specialist washes available. You can also do an 'overall' sludge wash or a targetted 'pin wash' depending on what effect you want. I would suggest that the easiest way for the first time is a sludge wash. Do it this way:
1/ Make sure that you have glossed your model first (should have been done for decals anyway) and seal the decals under a final gloss coat to protect them. With a water based varnish make sure it is left at least 24 hours to cure before applying a wash.
2/ Apply you wash - go all over the model and, for this, the clay based Flory washes are excellent. Apply plenty of wash making sure it gets into all the nooks and crannies.
3/ Remove the surplus. I use a cloth for this slightly dampened working in small areas at a time. Cotton buds are also useful is tight areas. Always end up wiping in the direction of airflow, thats important. Keep on gradually removing wash, leaving it in the panel lines and in the detail, until you get the effect that you want. The beauty of doing it this way is how controllable it is on the glossed surface and can end up with either a very tired and dirty aircraft or a fairly clean one with just the detail highlighted.
The colour modulation and washes work well together to get a good overall effect. Some drybrushing ofpigments can also help with, for instance, exhaust stains but this would be best over a matt coat, done after a matt varnish over the gloss and wash has cured.
I hope that helps.
I did a bit of a tutorial thread a while back if you want to read more about it. Here:
