Hi this will be my next conversion if you can put up with another one.
As you can see I've already started this.
Parts.
Parts marked are to be removed.
This is were the f/r shock absorbers and centre hatch will go.
Making inner missing wheels and rear idle wheels, trying to get some front sprockets and will be
fitting 1/35 track hopefully.
Totally removed all the hull details, added brass grills.
Totally remade rear panel, made exhausts and towing ponits.
Fitted gun emplacement, main gun and shield.
Will be using the old turret hatches on the rear engine deck (before & after).
Thank you for looking in.
Pete.
Parts.
Pete.
