papa 695's 1/24 Harrier GR3
papa 695
Staff member
Good one!!
Which markings you have on mind?
PS: Thank you very much to join in Ian :)
A GR3, does that mean you get to keep all those rivets ?
Well I've put this one off for long enough. But I've bought this to add to it
If you've seen Colin M's build of the Sea Harrier you will know that the rivets had to go so it's had a coat of Squadron Green put on and sanded off
At flippin' last........................................ I see rivets..............
Hopefully all your seeing Colin are rivet hole full of Squadron Green, once painted they should go :oops: :rolleyes:.
Yes, I remember going through that phase......................good luck.
Yes let's be positive.
At least until the first layer of primer goes on.
Looking good. Funny thing is, for such a large model, it comes together quite quickly.
Yes it does Colin the hardest part is locating all the parts on the sprues the numbers don't run in sequence
