papa 695's 1/72 Sherman M4 (two builds )
\ said:
Simply exquisite...:rolleyes:
Thanks Polux I had no problem with the resin I think the polystyrene was at fault with your Tilly build it say's not to use it at all
I'm really happy with your result Ian!!
If I send a Tilly....can you build one for me...? :) :) :)
Polux
\ said:
I'm really happy with your result Ian!!If I send a Tilly....can you build one for me...? :) :) :)
Polux
Anytime Polux but I don't think it would be as good as yours mate
Wow!
What flavor is the pudding/gelee?
Seriously now, will you keep in the container or remove it from there?
Francesco
Only just caught up with this, how did I miss it?
Erm.... Wow! springs to mind, that is some superb work there, and in 1/72nd too. Very impressive.
\ said:
Wow!What flavor is the pudding/gelee?
Francesco
It is out of the container Francesco I need to cut the lip away from the cast But that would mean lots and lots of sanding and polishing
real nice ,crusty body covered in coral and the turret looks just great left exposed to the weather for years, the diver came out real well also,seen happy
Hi Ian.
I asking myself...is easy to sand this kind of product? Leave marks or lose the transparency? :eek:
Polux
\ said:
Hi Ian.I asking myself...is easy to sand this kind of product? Leave marks or lose the transparency? :eek:
Polux
They say it can be sanded Polux as you would a canopy. I'm a little nervous to try it but I think I need to get rid of the lip left by the carton I used for the mould
i think you can cut it back useing a jigsaw with a fine blade,or buy hand with a coping /fine blade then sand it back,
and finely use wet/dry to get the shine back in, or ever give it a touch up with some resin painted on :rolleyes:
hope that some help
The name of that resin would be worth knowing...
The clarity is great and it didn't turn it into a blob!
Great work!
if you still have left over resin that you made the cast from use that, as as you saying some think else may meld it into a blob :oops:
best would be to test it on a bit off ,of cut and see how it go,s 1st or if it will bond with the other resin you used
\ said:
i think you can cut it back useing a jigsaw with a fine blade,or buy hand with a coping /fine blade then sand it back,and finely use wet/dry to get the shine back in, or ever give it a touch up with some resin painted on :rolleyes:
hope that some help
Thanks for the tips Monica. I will get this sorted soon
