papa 695's Honda CB750
papa 695
Staff member
Or build it oob. then park it under a bus. Then it will look just like my one did.....
A 'classic', without doubt!!! Very nice choice!
Go for it Ian... ;)
Polux
nice to see this go together....i was watching one of these on evilbay a week or two ago
I had a minor crisis last night ........ Sprayed a first coat on the engine and ............ there must be something on the parts I stripped the chrome off that reacted a little with the paint. I'm not sure what it is. I cleaned them off with soapy water after soaking them in bleach, they were rinsed well, well and cleaned with IPA ....... Anyway, this morning I cleaned off the couple of areas that had lifted and gave the engine a coat of black with a brush....... Tonight it'll get a second one.
Also last night I cut the seat down. Removed 20mm or so to take the pillion off to make it a single seat, bonded the tailpiece on with epoxy and dry fitted it to the frame with the tank and airbox........ Some filler and sanding next. Then I can cut the frame up some.
I'll post up some piccies tonight.
Peter
Great idea, I look forward to seeing the results of this.
For good ideas of where rust forms most on old 'stored outdoors' bikes have a search through Ebays 'project' bikes.
Good to see the start ................ If you are going for the scrapyard dio as well as the rust those alloy engines always corrode up nicely white deposits on the fins and stuff.
Peter
Nice start Ian.
To get a corroded/oxidized look just paint the areas with dilute PVA then blow talcum powder on (bicarb is too rough grained) when dry coat it with dilute silver paint to give the desired sheen.
That's a good base to try the talc technique, although I must say it looks pretty good as it is Ian:)
Wow!! Love the color work on this engine!!! How many CV have??? ;)
