Cheers Paul.Brilliant work, especially in that scale
Cheers JoeSuperb Ian. You have captured the hard life of not only the Typhoon, but also the front line endeavours of the ground crews.
Thanks PeterWell that looks fab mate, nice one.![]()
Cheers Steve, some very careful masking, and a bit of luck.That is a great result Ian. The work around the invasion stripe where it meets the raised bits on the fuzz must have been a challenge.
Many thanks indeedThose close ups don’t lie, brilliant work!
Many thanks Pete, it helps when you’re really enjoying the build.Excellent Ian. It's hard to believe it's only 1/72, I'd have thought it was 1/24 if you hadn't stated the scale, and it would be great work even in that scale.
Many thanks Tony.Excellent job Ian , its a very busy scene , you dont know where to look! The extra details look superb , definitely looks like a larger scale than 1/72 . Cheers tony
Cheers Colin.Splendid work Ian. As other have said, 1:72, amazing work.
Many thanksVery nice, the ground crew crawling over it really adds to it.
