Pauls Sturmgeschutz III Ausf B, 1/35 Italerai/Dragon
PaulTRose
Well-known member
just parking this here, not going to make a start for a week or two, need to clear the bench of whats already on it
i think this kit has been repopped by several manufacturers over the years.....not looking forward to all the individual tracks, especially since the Stug is slack-track
Hi Paul - there will be quite a few of us doing what is essentially the same kit. At least you get track links in yours - I just got really bad, hard vinyl in mine
Another one to watch. Will be interesting to see how the kits of the same version differ.
Hi Paul
Enjoy the build!
I would be interested in seeing a few close-up photos of the sprues, to compare to the Dragon kits. Just saying, in case you have time for that sort of thing :-)
Paul
Good luck with the build and especially those tracks. I knew there was a reason I stuck to quick-build kits!!
ATB
As I recall, those Dragon Panzer III/IV tracks are not that bad. I only ever put some together for a Warhammer 40K conversion, but they don’t stand out in my memory as having been a bad experience. Looking at the sprues, only two points to clean up, and they’re on the sides, so should be easy compared to some other types of single-link track I can remember dealing with over the years :)
....and they are miles better than the hard, flash riddled stiff vinyl monstrosities supplied with my Zvezda re-mould :smiling2:
sorry for lack of updates recently, real world things have had to take precident these last few weeks......but im at this point.......im going to try something whilst building the tracks which will mean i can paint everything and then add them
so this is on hold for a while.......the tracks are awful.......its a couple of hundred individual tracks that to be honest are a pain in the nether regions, and i just dont have the patience at the minute
so ive just bought some of these Miniart tracks........but not be here til the new year
Er Paul - haven’t you just swapped one set of individual links for another set that is more than likely worse to clean up and assemble as they have separate pins as well?
yes and no.....at least the miniart ones turn into proper tracks.....the ones in the kit have to be individually glued to its neighbour and arnt a good fit to start with.
Interested to see how the mini art workable tracks turn out....look rather fiddly :surprised:
Never had any fit issue with the Dragon Pz III/IV tracks, have done about 4 or 5 of those sets over the years :thinking:
so xmas didnt quite go to plan...........i was going to put everything on the bench to one side and just do something different just for the holidays....never even got to take the box off the stash pile let alone open it!
i spent a couple of days putting the Miniart tracks together which was sort of fun, definatly use them again, just hope they look right and have the slack track look
managed to spend a bit of time at the bench this morning and did some work to the hull.......which is going to be easier now im not using the kit tracks......looking forward to getting some paint on this now im making progress again
current state of play.....
painted......had a go at post shading, didnt work very well but cant be arsed to do more.......gloss coat.......decals on.......next step is a black enamel wash
the decals were a bit iffy.....theres two schemes in the box and had to combine decals from both to get something looking ok.......good job im not a rivet counter and couldnt care less about accuracy lol
slow progress
i will admit to a rapidly vanishing mojo at the minute....its not the kit, just life in general having an effect.....i had all sorts planned for this build, i was going to try a few different weathering tweeks, plus having a go at scratching a load of gubbins under a tarp on the back, cos i have an idea of something to use for the tarp.....dont think any of that will be happening now
next step is to see if those Miniart tracks fit
