PETES CLASSIC AIRFIX LOCKHEED TRISTAR
peterairfix
Nice one Peter.
If you want to avoid the hassle of masking all those windows, leave them out and AFTER the kit is built and painted, fill the openings with a drop of Kristal klear. When it dries you will have nice clean and clear windows. I'm only talking about the passenger windows. The cockpit, you use the clear part.
If I remember rightly Airfix airliners of this era used to provide a small plug that you were supposed to punch the window openings through the transfers. I could never get it to work as it always ripped the edge of the transfer. Your best option is to paint the stripe down the side then you can either use the kit glazing or use Klear as ian suggests.
I do have the plug but i havn't made my mind up yet as to decels or paint the stripe.
Peter t
Nice paint lines along the length of the fuselage Peter. Very clean, looks a nice model.
Si:)
Looking great Peter, good to see some more civilian aircraft , its quite a good size too isnt it. cheers tony
I was tempted to try coverting it to a tanker but thought ill leave it as it is.
Peter t
Nice work Peter. Just a suggestion, but maybe the engines could do with some enhancement, dry brushing or something of that nature to bring out the fans.
I don't believe it Joe but I was going to say almost exactly the same thing. I was going to suggest applying a wash in the engines to enhance the shadows. Maybe a bit of both would bring them to life
