Portable spray booths
I didn't work that out, I'm assuming there's an industry standard for hours of use, but I'll go with "until failure".
Depends on the contamination load and the air throughput rate, but I’d just go with “Until I can smell the extract” as a rule of thumb.
Would it also filter the paint particles as well as the smell or am I being a tad thick lol
Yes Bob (to both questions!)
I might get one myself, looked at the link and I assume 4 inch is the connection diameter?
Yes it is Bob.
I've one like Tim showed, goes straight through the shed wall . Just remember to change the filters depending how much you spray .
Yes it is Bob.
Great to see you back John, just ordered a filter. Despite the new room being insulated it's still a bit nippy, so leaving the window shut will be great for my old bones!!
If the hamster shows signs of slowing in his wheel i will sometimes weather permitting open the patio door for him.
If the light doesn’t work then that’s no big loss. At least, that looks very much like the one I have and the light isn’t exactly great — I always put a good lamp over the booth before I begin spraying, because the built-in light just doesn’t cut it.
