Pushing Back .......
It's a sickness ..... honest ...... where's me pills .... 😂
I'm still meddling in the mancave cutting balsa for tomorrow ....
the upper ceiling going in ....
going swell so far .....
I think it may even pass inspection ....
cheers
toto
Just about to leave the man cave for tonight having finished some prep work for tomorrow .....
Floor joist and roof rafters cut and ready to go ....
the Proxxon mini table saw has earned its keep today .....
it makes light work of all that cutting ..... over in minutes ....
cheers for now ....
toto
Back on the case ....
It's roofing time ....
and the victim ....
Should look the part once it's done....
time to hit with the glue .... normal PVA with a touch of black primer ....
and we commence .....
They will be secured further with some noggins but I had to wait for now ..... as usual ..... try to do too much in the one go ..... and you end up with a mess. I think the first load of glue will dry relatively quickly and let me bash on making further progress.
cheers for now
toto
Started doing the noggins .... but came to a halt as its too much .... too quick and I am starting to distort things ..... so I may call it a day for now ..... a couple of pic's before I go though.....
All the bare woodwork will get the wash treatment at some point.
an idea with the upper floor in place .....
and a bit of an ariel shot ..... not great but holding camera and floor ..... a bit of a faff.
hope you've enjoyed, cheers for now
toto
Hi Joe,
Very slow burner I'm sfraid. This working away from home doesn't help. However, enjoying it all the same.
Glad you find it of interest.
Toto
So .... back in Dounreay then ..... I'm spending my time looking up various window shutter types. I also have to decide .... just how much of the actual window frames survived the blasts.
My tasks this weekend will be to finish the roof and upper floor ceiling. I am thinking of putting flooring in the attic level. I don't think they would have had it but I need it to give strength to the ceiling structure itself.
Also .... once the roof joists and noggings are done ...... some battons to take slate tiles. I have sent away to diorama debri for three slate tile moulds. They should be here by Friday. ..... so ... more plaster casting at some point.
( update ..... slate moulds have arrived )
I think the underside of the upper floor ceiling will be created from daler board rather than attempting lathe and plaster. One of the other buildings lends itself better to the lath and plaster ceilings as the roof / ceilings has three sides for support rather than two. We'll see, not cast in stone yet ( or should I say plaster 😂 ).
More on my idea's later
Toto
Soon be back in the saddle.
Up to my neck in balsa, PVA and black washes later tonight.
Looking forward to it.
Toto
OK ..... in the mancave and immediately took a couple of steps back ...... I took out the noggings that I started installing as they were squint .... and just .... well ..... crap.
Started again.
there we go ..... no noggings but ...... an attic floor. I'll bet this would not be installed in the real thing but for additional structural purposes ..... we have one here.
and another shot.....
getting on now though ..... noggings back in ..... a bit straighter ....
and again ..... all this to be given several washes as yet .....
and the inside story ..... I'm hoping that these diagonal supports will be able to go once the overall structure is complete. we'll see.
and another look ahead shot .....
and one more for now.
tomorrow, its tile batons on the roof and ...... not sure after that.... washes ...... casting tiles.
I need to start thinking about painting the building...... oh and ceilings and window surrounds ...... never ends ..... but like the pain. 😂
see you tomorrow.
toto
well ..... it's time for a wash ..... a black ..... and green wash exactly .....
and the process starts ....
and turning to the underside ....
and the top ....
does not have to be pretty at all ..... rough as a ragmans trumpet if you like ....
black wash over for now and we commence with the green ....
I'll wait for it to dry and get a better idea of the finished article before deciding whether to give it any more .....
some washes leftover if I need it ....
and a couple of final shots for now ....
starting to take shape ..... about time as well.
back later
toto
OK ..... roof tiles underway .....
The tile mould x 3 and the infamous .... plasterboard sheet mould with which I have had zero success to date. Thought I'd give it another test drive today.
a bit of a mixed result ..... 14 out of 30 potential tiles. however, it is the first attempt which has been traditionally poor until I get the mix right.
how thin are these .....
delicate little devils.
26 out of 30 for the second mould ..... getting better ......
and the stock pile starts to build ..... just about another 150 or so to go ..... and thats just one building. ..... so ..... what am I doing here blethering ..... get casting .....
toto
Forgot to mention ...... wall capping stones ......
straights .....
end cap's ......
and corner pieces.
These will allow me to progress my walls a bit as well . Still a few to cast yet though.
cheers for now
toto
Well .... I'll be .....
wait until you see this .....
Not one ... or two ..... but three plasterboard sheets have come out of the mould .....
happy with that ......
luvvly jubbly ......
to give you an idea just how thin these casts are .....
anyway ...... more roof tiles and coping stones whilst I have the wet area set up .....
cheers for now
toto
so ..... its a waiting game ...... drying time is soul destroying ......
more tiles being cast .....
excess plaster skimmed off the top waiting for the mould to set .....
more coping stones on the way for the walls ..... in these moulds you get so many end casts and so many corner casts so it takes a few casts in order to get enough plain straight casts ....
another plasterboard cast ... if I get another three undamaged results from this I will be delighted ..... if so ..... the next building may have plaster and lathe ceilings instead of Daler board.
plasterboard moulds have been skimmed awaiting setting ....
and the waiting game ..... all part of the cycle.
I tried to order another 2 plasterboard moulds from diorama debri but they only had one in stock ....... I think they only produce a couple at a time and I like to have a minimum of three ( at least ) of every mould to cut down on the production time ..... so I'll keep my eye open for when they come back in stock and get at least another one ..... frustrating or wot.
toto
and more ..... never ending .....
slow progress on the plaster board sheet front ....
more tiles ...... yawnnnnnnnnnnn.
and we await the big dry ....
It will soon be over ..... I can only do this for so many hours ..... then its time to rip up some tile battons on the Proxxon.
hopefully I will actually get on to fitting the battons .... if not tonight ..... then at some point tomorrow.
painful or wot.
toto
OK .... that's enough of the wet works for today ..... back onto the dry ......
and here is where we left off ....
and it's back out with this little ripper ..... literally ....
and the first row of batons go on ....
the first row of tiles will be on their side ....
and the second row will overlap them ..... weather proofing the bottom edge ....
meanwhile .... back at the ranch .... more battons go on ...
until we are done ....
and we'll leave that lot to dry until tomorrow before attempting to start fitting the tiles.
That will be all for now.
cheers
toto
