Revell Learjet 35A/C-21 USAF/USAFE
Ha ha, was going to say makes a change from military to build a civil but then the penny droped when I saw the decal sheet Dohh :) looking very good.
Great work Terry and love the idea with the blinds that's one I will pinch
Looking good Terry, really like the interior. I've built this kit and enjoyed it, looking forward to seeing yours completed.
I like this keep up the good work, will be continuing to watch.
scott
Thanks guys for the kind words.
Last night I put the wings on there is only a little filler needed in one of the wing roots. I may have to take the rear ones off and redo them as I think the up sweep is a bit to much. What do you guys think?View attachment 89786
Tail planes should have a 0deg dihedral. That would be flat to you and me.
Cheers Ian that is how I thought it should be. easy enough to correct as they are only fixed with CA.
Looks good Terry. As Ian says, there is minimal dihedral on the tail planes.
Thanks Joe I have rectified them this evening and they look as they should now.
Tonight I have started some work on the engines. As there is a difference in the military variant I am altering them accordingly. I am going to add thrust reversers made from styrene sheet but before I do that I need to lessen the depth of the engine mount. On the Learjet 35A there is more of a moulded look to the engine as can be seen below. The left hand engine has been altered ready for the reversers to be added with a little more sanding to be done. Where as the right hand engine is how it came out of the box. View attachment 89929
Doe sit have bucket reversers on the exhausts Terry? Most early Learjets had no reversers, some had a drag chute. Doesn't make for efficient operation at short airfields, or indeed at any airfield if you drop the chute.
Looking good Terry, never realised what a nice looking aircraft this was.
Thanks guys, Joe it does indeed have the buckets I didn't know some of the earlier ones used break chutes. That would explain why on some pictures I have looked at they appear to have a cap on the tail of the airframe. All the ones that I have seen go through Fairford have had the buckets fitted. It has got me thinking maybe the USAF ones have been upgraded to give better operational capabilities.
