Revell Monty's caravan & scout car (1/76)
Jim R
Hi all
Having finished the Jaguar SS100 I had a rummage through my limited stash and came across this. Bought a few years ago at the Perth Model Show.
As well as the two vehicles it comes with a base and three figures. It is a rebox of the Matchbox kit from the early 1980s. I don't plan on using the kit base but will make one myself. For an old kit the sprues look OK. A bit soft in detail but no flash.
I have made a start and I'll update progress later. Anyone who is interested in following along would be more than welcome.
ive done this before so i know its builds up nice..........got another im planning on doing soon......love these old matchbox/revell repops with the little base
Nice one Jim, one of my favorites from the old Matchbox line.:thumb2:
Will tag along to see how yours comes together and looking forward to see the base.
I built this when I was maybe ten years old, and again 10–15 years or so later. Always liked it, and pretty much any other 1/76th scale Matchbox kit for that matter :) Pity Revell don’t mould it in three colours anymore like it should be.
Paul, Fernando, Jakko and John - so good to have you along. Especially pleased that many are familiar with the kit and so will be able to offer advice from first hand experience.
I started with the Daimler Mk2 scout car. The fit of parts just required minimum fettling to get a good fit. Filling was needed at the base of the rear. The suspension springs were moulded OK but the seam lines were front and back. Impossible to clean up and I wasn't sure if the line would show so scratched new springs with rod and 0.3mm wire. The interior - what there is of it - was painted and weathered. The two seats are still to fit.
I primed with Stynyrez grey but used black for the wheel arches. Hopefully if I can airbrush the top coat 'gently' I will get a bit of shadow/variation. That may not work as I am rather heavy handed :sad:
This scale is TINY!! Admiration for people like Paul E who works with even smaller models. This is it photographed with a no11 scalpel blade :smiling5:
Thanks for your interest and support.
Jim.
Either that is one large blade or you have gone to the darkside of scale .:fearful:
It's no wonder the springs were hardly useable, the ones you have done look spot on.
Primer is good, can't be easy with that size, did you have to nail it down ! :smiling3: I'd have blown it off the turntable :smiling::smiling:
John .
Good-o, another small one :thumb2:
Springs definitely needed replacing
Still have one (possibly more) original Matchbox multicolour in the stash
There's actually quite a lot of stuff squeezed inside these little chaps - this one was at Elvington show a few years back
View attachment 314098View attachment 314099View attachment 314100
I'll pull up a pew, this looks good, every time I see the word Leyland I remember the Leyland P76 we had, people said it was a dreadful car but I can't remember anything bad about ours.
cheers
Ross
Sorry Jim! Late on parade again. What a fantastic little build. Looking forward to seeing how you tackle this. Is there detail inside the caravan - tables, chairs etc?
Hi all
John - it was primed blu-tacked to a lolly stick otherwise it could well have blown around :smiling5:
Simon - little will be seen of the springs but I took a leaf out of your book and replaced them anyway. The Dingo was quite an amazing little vehicle - many, many made and appeared everywhere.
Mick - to be honest I didn't realise just how small this scale is especially for very small vehicles.
Ross - welcome aboard. Leyland was a big manufacturer back in the day but now just history.
Steve - there is no interior for the caravan. I will scratch a few odds and ends just so it doesn't look empty. See the update.
Fernando - cheers :thumb2:
OK update time. Not a lot to shown for the hours I have spent peering through the Optivisor.
I got a base coat on the Dingo and then a coat of gloss
Built up the caravan chassis. Went together OK but the location points for the various parts took a bit to figure out. Held in place with magnets onto a steel sheet with square paper stuck on it to keep everything square. Then primed black.
Front and rear of the cab built and primed.
Then I tackled the office/caravan itself. As I said to Scottie there is no interior. Just a large map bench along one side and that is not the right shape. The walls of the caravan had those rotten casting circles on the inside :sad:
The real thing is at the IWM. Very few photos of the interior. For ref only
The far end is divided off into a washroom. I scratched a few bits to fill up the empty space. Cupboards on the wall, a table, a chair, a wash basin, a toilet? and a settee.
Not very accurate or to scale but painted up it will be good enough for what will be seen.
Cut the door out of the dividing wall so the door can be modelled open.
So that it where the time has gone :smiling3:
Thanks for all your support.
Nice start at the painting Jim.:thumb2:
Looking forward to see how the caravan looks with the interior installed.:hungry:
Thats a wonderful update Jim. The furniture and interior work has come out well. Damm that Dingo is small. Great stuff mate:thumb2:
Hi all
Scottie, Fernando and Steve - thanks for the kind comments. Sorry for taking so long to acknowledge you posts.
So time for an update. Loads of fiddly, time consuming stuff - quite fun though.
The Dingo is almost complete. A bit more weathering and wheels to fit. I won't do any chipping 'cause I can't see how to keep it in scale considering the whole thing is only about 3cm long.
The truck cab interior is done. No clear parts in the kit so windscreen had to be made.
Monty's caravan interior completed. Very fiddly and I doubt much will be seen but I am sure all of you have built and painted wonderful, hidden things - seems to be something we do!!:tongue-out3:
I am sure a far better job could be done especially if the scale was bigger but it's better than just the kit provided map bench.
You could leave the caravan roof loose, so all that nice interior can still be on show.
Jim.
That is brilliant, great work on the internals. Don't think it could be bettered really. Everything looks right.
Have to agreewith Jakko, you have to leave that roof removable. Too good to seal up.
John.
