DONT worry John he'll do both as he is good at multi taskin lolCongratulations on the opening of your model room Bob .
Still not sure about you being converted to floaty things, very worrying for the StuG Society.
chisb
Cheers, thanks sir!We'll,I for one,think that looks really good Bob :smiling3:
Very nice indeed![]()
Hi Tim, does not matter what I do the seam stands out like the old sore thumb! In this case I have not used filler and its just the seam between the hull halves, especially at the bow.Looking good Bob. Black suits it :thumb2:
What is the issue with the seams? Are they sinking after preparation? If so, you aren’t leaving them to dry long enough before sanding down, especially if the filler is quite thick. As the trapped thinners gasses off the filler shrinks, so making the seam visible again. Try putting it on in thinner layers and allowing them to dry properly before sanding.
Thanks TimHave you tried adding Mr Surfacer filler over the primer? You just blob it on where required using an old brush, let it dry overnight, then sand it off. Worked for me on the mosquito build…..
Another thing, how are you sanding the seams? Are you using a backing on the paper? I always find it better to mount the paper on a hard backing substrate so you don’t sand any hollows into the surface.
Normally use deluxe materials, but on this case no filler just the pesky seamWhich filler are you using Bob? Could be it’s crumbling out of the joint as you sand it?
Hi Stevr, not a problem, delighted to see you on board!!Must have been on another planet to have missed this one Bob. Ever so sorry my friend. Had a very nice read through. Will keep a closer eye from now on. Take care my friend and happy modelling
Thanks Jim, appreciatedLooking good Bob. Can't offer much help with your seam problem, sorry. The only suggestion is sometimes before sanding something like a seam I give the area a coat of paint, any colour that contrasts with the styrene. Then when you sand the area you know that any paint left shows a low area. So a seam will show a line of paint if it's still there.
Bob owm8ty i think you are bein to fussy just build the sub an dont worry an enjoy the hobby
Thanks Chris, have applied some Mr surfacer 500 to the seam, go to get to grips with seams!The big beast looks great. Details are very good. I think it will be a very good finale.
ismet guralp.
Danke Herr Pete, das buggering off to the black sea they will never find it in there lolDer unterseebooten ist looken fine mit der primer Bob.
