How did you do it? I'm experimenting right now on making convincing rock, as good as yours. The colouring is superb, as is the surface lumpiness.
(I'm assuming it is a model!)
This is the stuff I used Steve , I got it from Hobbycraft it was about £15 I think bit pricey but as you can see it gives a good effect\ said:How did you do it? I'm experimenting right now on making convincing rock, as good as yours. The colouring is superb, as is the surface lumpiness.(I'm assuming it is a model!)
And an elephant, 4 legs and a trunk.\ said:Looks great. Don't know if my imagination is running riot but I can actually see about four faces in there!![]()
Steve, not a patch on Alan's rock face, but I did something similar to your suggestion.....It's in the 'How to' section entitled 'A ten minute rock face'. It might be of some use as a poor man's alternative to Alan's excellent example.\ said:for example building a rock face using crumpled aluminium foil as a mould (or, I have just thought, use the crumpled aluminium directly as the rock face after strengthening on the back with plaster or squirty foam from DIY shops, then paint the aluminium.)
View attachment 98607\ said:Drugs or beer required for this one as I can't see anything![]()
I have searched 'How to' section entitled 'A ten minute rock face' to 2006 but can't find it. Have you any more details please? Thanks.\ said:Steve, not a patch on Alan's rock face, but I did something similar to your suggestion.....It's in the 'How to' section entitled 'A ten minute rock face'. It might be of some use as a poor man's alternative to Alan's excellent example.Sorry for the hi-jack Al'.....
Thanks Ron there are a few ways to do rock but I don't think you can get as an effect as a mould yes it costs but worth it imo\ said:Steve, not a patch on Alan's rock face, but I did something similar to your suggestion.....It's in the 'How to' section entitled 'A ten minute rock face'. It might be of some use as a poor man's alternative to Alan's excellent example.Sorry for the hi-jack Al'.....
Sorry Steve, it should read...A 10 minute cliff face. It is there, but I gave you the wrong title. It's nothing special, just a quicky idea really.\ said:I have searched 'How to' section entitled 'A ten minute rock face' to 2006 but can't find it. Have you any more details please? Thanks.
Quite right Alan, that mould of yours is spot on. Mine in the 'How to' is just a quicky experiment really.\ said:Thanks Ron there are a few ways to do rock but I don't think you can get as an effect as a mould yes it costs but worth it imoPolystyrene is a good way to get a good effect![]()
Got it! On your first photo I particularly like the way that you got the cliff to overhang. I discovered this foil technique a few weeks ago and was thinking that it might not be necessary to make a rubber mould first and then cast the stone in plaster. Your post confirms that. I am about to brave the arctic garage this morning to do a first experiment. I hadn't thought of painting it first.\ said:Sorry Steve, it should read...A 10 minute cliff face. It is there, but I gave you the wrong title. It's nothing special, just a quicky idea really.
The way I look at it if you do a lot of dios I think it's worth it as it takes minuets to do and a few hours to complete\ said:Quite right Alan, that mould of yours is spot on. Mine in the 'How to' is just a quicky experiment really.Polystyrene is my favourite. for rough rock, stone work. I'll have to save some pennies and get one of those moulds soon. Excellent result....
