scotties pioneer.
Scottie, just had a catch up That power plant...even without the fan is the Bomb. Super job of detailing and scratchery!
Rick H.
The chassis has now received a gloss coat ready for the weathering and detailing.
The counter weight carrier has been completed from a mixture of kit and etch. The round brace was added from round styrene. This will be detailed before I add it to the chassis.
Next I have started work on the winch, This is again a mixture of kit, etch and scratch. The cord looks a bit fluffy at the moment but when under tension it looks a lot better.
There are a few rough edges I have spotted to be removed.
Scottie
All crazy work Scottie in a good way. :thumb2::thumb2: The scratch work is tidy and neat...where do you hide the glue. :smiling6:
He clearly doesn't use glue Richard, everything is held together with "The Force" :smiling5:
Thanks Richard, happy you like it.
Cheers Andy, wish it was mate.
Jaw dropping work Paul. I'm really impressed with the detailing and finish so far on the engine and chassis. A joy to watch
Impressive stuff Paul, enjoying seeing the Scammel coming together.
Can I just confirm this is a model and it’s not you just taking pics of an actual pioneer that you’ve dismantled and are now reassembling? :tongue-out3:
Thanks Graeme, hope you can stay as still lots to do.
Toby, Thanks fella, very kind of you.
Added the weight box after picking out some detail and adding a few scratches to the weights.
Next I made some air couplings from bits of evergreen. Look ok using the 2meter rule.
Then it all received a pin wash. The final work will be done when all assembled.
cheers
Scottie
Marvellous. Your eye for the true wear and tear on materials is astonishing.
A little work on the jib. I made a chain as the chain i have is to large.
Another disappointing thing about this kit is that all the wood has no grain effect. So I have added it to all surfaces including underneath the main block. None of the lockers have the choice of being shown open, so I decided i wanted one of them to be open. This meant cutting of a lid to gain access. Next a partition was made inside from evergreen sheet. This also needed the woodgrain adding. Rudimentary hinges were added they wont be seen as the lid will be opened. Finally some rivet detail was added along the face of the partition.
Finally a lid was made from evergreen and woodgrain added. Bracing strips, rivets and a handle was added. It will be added later in the build.
cheers
Scottie
