SimonT - 1/24 Abandoned Mini
Cheers Scottie
Did some more work on this - added the other shoe return spring then made the wheel hub with bolts which nicely covers up most of the internal detail :rolling:
Added a few bits to the sub frame to fill in missing bits of the kit pieces
Just found that I forgot to take pictures of it :smiling4:
Morning Simon
Up to your usual insanely good scratchery standards.
Thanks Jim - tried to thread the studs with my jewellers die but it wouldn’t cut a decent thread so gave up and just used plain rod
You never change Simon, the only person I know to go to this amount of insane detailing on a build. Must be the water up there !
...must try harder......so I did
thinking about it logically watchmakers, that these small tap and die sets are aimed at, don't work in plastic so I tried it with some brass wire instead
Success
Replaced the plastic studs with brass ones all having a threaded end section
the thread is 0.7mm - it is so fine it will probably vanish under paint :smiling5: oh well
while I was at it I also added the Schrader valves on the rear of the sub frame - these are used to pump in, or pump out, the hydrolastic suspension fluid (rather nice looking fluorescent green liquid) at great pressure
added the hydrolastic pipes that run from the Schrader valves into the hydro displacer units housed in the sub frame using 1mm lead wire
outstanding! PaulE
Hi Simon
My gob is well and truly smacked although I shouldn't be surprised given your track record for this sort of scratch work.
Thanks Paul
Ian
- thank you, could have done with you marking my 'A' levels :smiling5:
Neil - you are more than welcome, thanks for following
Scottie - I've owned real ones that were nearly as rusty that still started :smiling5: Unfortunately the big bad MOT man refused to let me drive them for some reason:thinking:
Jim - thanks. Luckily, having owned a few over the years, I can still more remember what a lot of it should look like which helps
added the radius arm fixings last night - still need grease nipple adding
and the rear subframe mounting pins - looks like they will need a bit of tidying once the VJ filler sets!
You're going to add a GREASE NIPPLE? That is extreme detailing Simon, cracking build.:thumb2:
here we go, one grease nipple - 0.5mm hex rod carved to a ball shape at the end
should be a bit smaller really of course but it gives the impression
Nice work on the nipples Simon ( aww come on guy's keep the thoughts clean )
Very nippley indeed:smiling2:. PaulE
Best nipple I've seen for ages! ;)
