SimonT - 1/35th Tamiya T62 (well worn)
Thank you one and all
The embedded armature wire helped a lot as it gave me something to pull on but I shall try some mould release as well next time
turret in place with a mock up of the barrel
Four days off Mr T!! I expect this to be finished and primed by Tuesday! :smiling5: :smiling5: :cool::thumb2:
Great stuff, Simon, quite inspiring ! I love the Idea of casting plinths- it's a good way of not wasting excess resin( if you can pour it all before it goes off!) I suppose it could be built up over successive pours as well?
Hi Neil,
they can be poured all in one go and once you know how much resin is needed there isn’t much waste
They can be built up as well - I have just poured another turret and used the small amount that was left to start another plinth
morning all,
The turret ring side cheeks are way too shallow so I have added a couple of strips to them and clamped in place with pegs
They will then need some work with the filler to put the curves back
I was looking at that photo and wondering what it was that you were clamping there :) Not pulling any punches with this model …
Just done with phone same as usual - got them in focus this time though :smiling2:
reshaping of the cheek parts underway
also started assembling the gun barrel bits but couldn't get a decent photo
the cheek parts were doubled in depth by adding strip and filler to the underside of them
this extra material was then sanded back to refine the shape to more closely match the reference photos
once offered up to the hull it became clear that the basic shape of the top of the kit part was also incorrect, with a definite droop towards the outer edges rather than being flush with the top of the hull
I decided the best way to tackle this was to mount them on the hull then pack out the bottom edge
this pivoted the cheek parts such that they then lined up with the hull top
the whole thing was then blathered in Squadron green to fill all the gaps and change the profile of the edges
once this sets, which may take a while for such a large amount, it will be all sanded back to the required shape
I'm sure you are Heinrich Dorfmann in disguise :smiling2: :smiling5:
Outstanding work with the green stuff
It will fly Mr Jones....
Much more green than it actually needs so that I can sand back to shape
:smiling5:
on my last tube of the good stuff - that new stuff just doesn't seem anywhere near as good
very sloppy and oozes out the tube as soon as cap removed :disappointed2:
Simon I'm coming to the conclusion that Squadron Green fumes must have effected you over the years, thus this cause of extreme scratchery also the ingestion of certain potions.
Young Jones is not far behind either !
Morning Simon
Lovely cheeks. Ladies pay a fortune in Harley Street to have their cheeks done - you may have missed your vocation :tongue-out3:
:smiling5:
Simon I found the same so I gave the tube a gentle massage to mix it up then stood the tube on its cap for a few days it is no pretty much but not quite as the old recipe.
Could be John :tongue-out3:
They might not like the green look though Jim
Scottie - I have massaged the tube to try mix the contents but not the standing part so will give it a try, ta
ground out the turret figure bins, added 3No. new pins around the left aperture and filled the air bubbles - just needs a little tidying
