Morning all,
bought this for the under a fiver build but decided it was a waste of time just slapping it together to create something I wouldn't be happy with so it got promoted to a proper build
Started Saturday evening and had it mostly finished by last night - very speedy by my usual standards
You may notice this is tagged as limited edition on the box - the reality of this is that they deleted all the nice truck body parts and replaced them with a small sprue (the black one in the photos) of fuel tank parts made from really poor quality plastic
it is so bad that it is in layers that peel off - really weird stuff
didn't take too long to remove and clean up all the parts ready for construction - as you can see the floor pan sinkage has already been filled
here are various pictures of the current state in no particular build order as they were mainly taken at the end of the day last night
solid front wings were ground out
front seats textured and mounted on the floor pan - kit would have you fit base to floor and the back inside the cab but it will be easier to paint this way
tank got new (sorry, rather fuzzy) bolt heads on the top filler hatch
i added a valve hand wheel from bits of stretched sprue - this is guesswork as I couldn't find any photos
the kit comes moulded with a front bumper but the instructions tell you to cut it off and make your own bar to fit between the chassis rails
added a radiator cap
added bonnet clips
added some tread for the running boards
fuel hose added from Duro
made a bucket and hook to hang it from - always need a bucket
cage added to the spare wheel
brass tube replaced the kit back axle inside that diff housing and the prop shaft
also made a brass tube tailpipe for the exhaust as kit exhaust has no tail pipe
cab from other side - this has been left removable to aid painting
added bonnet clips
