Was up in the stash earlier on looking for something none modelling related but had to shift a lot of the kits - found an unopened LS 1:1 Remington Army, a Verlinden 120mm Kubelwagen and an Italeri RSO/01 that I had forgotten about. (recently bought another RSO - oops). Also found that I have four 1:25 Tamiya Tigers and at least two of the 1:25 Centurions. Also came across a Dragon Scud B which I knew I had but couldn't remember quite where I had put it
Anyway, decided to use todays modelling time to do a little more on this one
added some detail to the inside face of the drivers visor
installed the visor then added a stay and some bolt ends for the hinges
bit hard to see but have undercut the solid shovel bracket on both sides so doesn't look solid
the back end of the shovel was just left floating about - you wouldn't keep you shovel very long like that so I added a tie down
the front track guard supports were not wide enough so I cut them off, drilled the bracket and added some lengths of brass tubing
also drilled out the headlight and the siren horn
front door handles replaced with plastic rod
the hull and turret rear grab handles were also replaced with rod
nearly there now - mg to add to turret and the track guards to make
in spite of the various small errors I rather like this little oddball tank
