SimonT - Tamiya 1:35 Sturmmorser Tiger (AAGB)
Steve - thanks. Pity the stencil didn't work
Jack - probably looks better from a distance :smiling3:
Peter - thanks. It has toned down a bit now after the filter and wash
Smiffy - is that the Mr Smith, he of the green paint. Good to see you again. Drag your Sturmtiger of the shelf and get it built! :smiling3:
Jim - the mask looked good but didn't really work in practice. I actually ended up brush painting the patterns.
Graeme - thanks. we shall see
before starting working yesterday morning I applied a layer of migAmmo filter for three tone camo - basically a posh name for brown - and left it to dry all day
last night I applied 'filth' to the insides and a wash of brown for german yellow on the outside - again posh names for brown. Hmm, i think there is a pattern to these migAmmo potions - they are really all just brown with different names applied to the bottles
left it to dry for a couple of hours then wiped most of it off again with little foam make-up sponge sticks and odourless thinners
this is the result so far
Looks like the various snake oils have worked pretty well Si- the beast is looking like a cover photo for a Mig box of filters! I especially like the ambush camo you’ve done too :thumb2: (Yes, it is that Smiffy, btw)
Never be that good Al but thanks
remembered that I hadn’t finished off the mould for the rockets so just mixed up some rubber and poured the mould
Morning Si
Looks the part and the weathering is adding a subtle tone to reduce the glare of fresh paint
Well done and it looks like it will get finished too
Steve H
Thanks Steve - you never know, may actually get finished, although not for the end of the GB
Morning Simon
That migAmmo stuff has worked nicely. 50 shades of brown :rolling:. Is it enamel based? The mask did look the part. Was the problem getting it in contact with the surface? Shame how sometimes good ideas don't actually work. I once bought some wood grain decals at a show - should have spent my money on another cup of coffee or ten :tongue-out3: Hope the rocket mould works ok.
Take care
Well, the GB end has come and gone again and of course this isn't finished
Jim - having shelled out for all these mig/AK potions you're right, I could have just got a gallon of brown instead :smiling3: Yes they are enamel. The good thing is they can be used over the acrylics without damaging them - you liberally splash them on all over then use odourless thinner to remove a lot of it again. Part of the problem was getting the paint to spray - I should have tried with Tamiya instead. It worked in a couple of places. I did have trouble getting it to stay stuck down as well which didn't help. Definitely user error rather than the stencil
Steve - that's the extent of the interior work. Not much can be seen once the upper hull goes on
Scottie - ta
Have done a little more
went around and highlighted the spotty bits using the highlight from the modulation set
attacked the tracks with dark, medium and light rust potions from AK
I think they are looking nicely rusted and metallic
engine finally painted
panzer grey mixed with smoke
ancillaries painted with a lighter grey
pipes and hose clips picked out in black or flat aluminium
air filter tops dry brushed white
whole thing then got blue for german grey followed with engine grime
fans painted flat aluminium then engine grimed
drive teeth rubbed with polished metal pigment
the first track
the inside running faces were coated in polished metal pigment applied with one of the small foam make-up brush
outside had some light dust rubbed in
I used odourless thinner to fix everything - it dulled down the polished metal nicely to a burnished metal colour
stig-145_2020-4-7.jpgstig-146_2020-4-7.jpgstig-147_2020-4-7.jpgstig-148_2020-4-7.jpgstig-149_2020-4-7.jpg
tinkered a bit more with this one - it looked ok to the eye but having seen the photos I think it needs a little more blending of the dirt streaks
Scottie / Steve - cheers
This one is still progressing, albeit slowly
Various tweaks done for shading and streaking various bits
Buff Oilbrusher used to fade the colours together
Test fit of one track
